Replaced dash cluster, need Odometer help/advice
VGMStudios
Canada
This version looks quite a bit different from what we have in the U.S. I was thinking the ring and possibly other areas were screen printed but see you bought a later version and modified it. Good work.
No no no. It's not a new cluster or one from a 2010+. The cluster itself is from my 06 GT. I simply added a new cluster face to the 06 one and added the blue ring lights and whatnot. The whole cluster face is customized. But thank you very much.
Blue03Cobra
Baton Rouge, La.
Close this one out. I found an online provider (in NJ) that repairs and re-codes clusters. I sent him my original four-gauge "Deluxe" cluster, to prove the odometer reading and the Pick-and-Pull (BYOT - Bring Your Own Tools salvage yard in Port Allen, La.) "Premium" six-gauge cluster and he replaced all the moving parts and reprogrammed the ODO, for $150.
Totally satisfied. He also repairs mechanical/classic ODOs and tons of other programming and mechanical gauge fixes. I give him five stars:
Autokyrios
VA, USA
Been looking for something different. I've tried several aftermarket face changes but they all turned out to be crap. Had one that was yellow, looked okay at-rest but was very hard to read. Switched to a white face version that was easier to read but the illumination isn't as good and the info center is a bit fuzzy. Still have my stock faceplate so may switch back to that. My whole thing is clarity of information. I could give a sh** how cool it looks, if it can't tell me the info I need at a quick glance, or it annoys the hell out of me, it's garbage.
ticket collector
lousaina
No, US car and taken from a US salvage yard (Baton Rouge, LA)
I found a YouTube where the old ODO unit was removed (soldering required) and inserted (re-soldered) into the new cluster. That's my final "nuclear" option. I found a OBDII scanner, that purportedly can adjust the ODO, so may give that a try, as well.
I also have access to ForScan, would that have the access/functionality?
which salvage yard ? and do they have any 2006's?
