Rocker Arms and Lash Adjusters
wildbillcody
tennessee
Im doing a little bit of an budget build. First a little background on the car as it sets. Its a stock block with the FRPP whipple kit, the plan is to run about 600rwhp and its already been on the dyno and has had 500hp for the past 3yrs. I have a forged 4v short block that has been bored to a 5.0 and been machined for 3v heads. I plan on running comp 127350 cams and limiters, 47lb injectors, and getting the 13/14 oil pump. Now do I go ahead and reuse the stock rocker arms and lash adjusters or is the ford racing set really that much better. I've seen threads on spring failures and some on rocker arms but they were running a much bigger lift than the 350's. I will be using comp springs and titanium retainers.
