rough idle after engine warms??
doc dilligaf
Dayton,Ohio
Gentlemen I need some advise please. I have an 06 gt w 59k. Changed plugs about a month ago. Air filter as well and oil change. Since the plug change the car will rough idle after sitting at a red light. If I push in clutch and give it gas it goes away? It drives fine while moving. The fan is working fine. I was thinking cracked plug maybe? However it seems there would be a rough idle all the time,not just after it warms up. No fault lights are active on the dash. Thanks for any and all help in advance.
07 Boss
Sin City
Hmmmm..... ever since you changed the plugs it's been idling rough. I wonder what it could be.
Mikes06GT
North Jersey
Sounds like a possible vacuum leak also. Check all hoses since you changes air filter also
