BadPiggy
Hooligan Ahole
Which is the better of the 2?
After reading on another thread that Whiteline has recalled their Adjustable UCA's...I'm left to wonder if in my case, it's even worth changing at all. My whip currently has the ROUSH Anti Wheel Hop UCA on it, straight from ROUSH factory. ROUSH also installs their lowering springs from the factory. I've since replaced the ROUSH springs to BMR, changed LCA's to Whiteline adjustable and the Whiteline relocation brackets. I've also installed a one piece DSS driveshaft.
Since Whiteline has the recall on the UCA and I already have Adjustable LCA's which will allow me to change pinion angle, should I even bother changing the Roush UCA?
I venture to say ROUSH took into consideration pinion angle and their UCA was, I'd assume, built with that in mind...which would mean it's already setup for a lowered car.
Thoughts?
Thoughts?
