The time has come.
Looking for a 11-14 coyote for the prototype kit. Still need an automatic!
Kit design will be similar to our Stealth 05-10 single kit (seen below) with a low mount Comp 80mm billet wheel triplex ceramic ball bearing gen2 oil-less turbo, so no relocating engine bay components, no routing exhaust piping into the engine bay and nothing under the k member or lower than factory exhaust. Removing the turbo and exhaust piping from the engine bay greatly increases power and performance of the turbo system while not throwing a bunch of heat into the engine bay to melt and damage components. Turbo is located where the factory cat would be which is the hottest part of your exhaust system. All piping will be coated and kit will include heat wrap as well. The turbo is water cooled and has a zirk fitting for self greasing at regular intervals, so no sending the turbo in for seal replacement every few years. Maintenance interval for the gen2 oil less turbo is the best on the market, grease with every oil change or every 3-5k miles, with a recommend bearing inspection at 50k miles. A single cartridge of high temp synthetic grease will last the life of the setup. No tapping the oil pan for a drain or worrying about oil seals leaking and smoking out the exhaust. Plan is for a 3.5" downpipe, with cutout and y to connect to stock over axle pipes. 4" race core air to air intercooler and all cold side piping coated as well. Dual Tial MVS 38mm vband waste gates with all the springs and our 50.5mm bov. Looking to have the most advanced coyote turbo kit on the market, capable of 600rwhp on low boost 4-5psi and that spools faster than any other kit. All while supporting 1200rwhp+ on the big end with a built motor with the base kit, so no need to upgrade components as you push for more power. Prototype kit owner will receive a free dyno tune from Dan Desio at Pro Dyno! Also offering discounted fuel system and injectors if needed for this kit.
Contact us for more details! Need an automatic car for mock up. Will need the car for 4-6 weeks and location is Statesville, NC.
Looking for a 11-14 coyote for the prototype kit. Still need an automatic!Kit design will be similar to our Stealth 05-10 single kit (seen below) with a low mount Comp 80mm billet wheel triplex ceramic ball bearing gen2 oil-less turbo, so no relocating engine bay components, no routing exhaust piping into the engine bay and nothing under the k member or lower than factory exhaust. Removing the turbo and exhaust piping from the engine bay greatly increases power and performance of the turbo system while not throwing a bunch of heat into the engine bay to melt and damage components. Turbo is located where the factory cat would be which is the hottest part of your exhaust system. All piping will be coated and kit will include heat wrap as well. The turbo is water cooled and has a zirk fitting for self greasing at regular intervals, so no sending the turbo in for seal replacement every few years. Maintenance interval for the gen2 oil less turbo is the best on the market, grease with every oil change or every 3-5k miles, with a recommend bearing inspection at 50k miles. A single cartridge of high temp synthetic grease will last the life of the setup. No tapping the oil pan for a drain or worrying about oil seals leaking and smoking out the exhaust. Plan is for a 3.5" downpipe, with cutout and y to connect to stock over axle pipes. 4" race core air to air intercooler and all cold side piping coated as well. Dual Tial MVS 38mm vband waste gates with all the springs and our 50.5mm bov. Looking to have the most advanced coyote turbo kit on the market, capable of 600rwhp on low boost 4-5psi and that spools faster than any other kit. All while supporting 1200rwhp+ on the big end with a built motor with the base kit, so no need to upgrade components as you push for more power. Prototype kit owner will receive a free dyno tune from Dan Desio at Pro Dyno! Also offering discounted fuel system and injectors if needed for this kit.
