SCT LiveLink Gen II datalogging problem
SalD
I am attempting to datalog for Lito but I keep running into the same issue while datalogging. My Intake Air Temp PID does not show the correct temperatures when using a config file set up with PIDs and DMRs.
I can get good temp readings if I try using just PIDs but when I add the DMRs in the PID for Intake Air Temperature starts showing wildly wrong readings (16 degrees, 48 degrees, 248 degrees, like that) after a minute or so of datalogging.
I have tried datalogging on two different Windows 10 laptops. It's very strange that this one PID goes nuts each and every time.
SCT tech support is non-existent so I am trying here. Help.
Charly
Did you do updates for SCT, just a suggestion, also do updates for Live Link Gen 2.
SalD
I've done all of that. I updated to the latest versions as instructed through email by SCT Tech Support so they tell me to call them and their answering system hangs up every single time.
I even recently tried to run it with the downloaded install with no updates and the original database, still the same issue occurs.
I can read the correct IATs from the SCT X4 if I datalog directly to it so there is nothing wrong with the car or the X4. It's SCT software that is causing this and I cannot find anything that will work.
SalD
My first two datalogs did not show this issue, this issue popped up on my third datalog for Lito and now it occurs every time I have the DMRs in the list.
