Shaker 500 reinstall problem
07stangcs
Undecided
Houston,TX
Took the SOS gauge bezel and dvd player out and putting the old Shaker 500 back in. After putting everything back together the radio doesnt turn on????? WTF? Is there a process i have to do to get it back on? Didnt think these radio's had any anti theft protection. Anyone know whats up?
EDIT: I hear its linked to the ECU somehow. Gonna flash to stock tune and back to the KB tune to see if it helps.
Hawgman
THE fucking bad guy
Texas
Ok, stupid question(s).
1 - The system you took out, did you use the factory harness with it or did you wire everything new?
2 - If everything was wired new, have you checked to see if the fuse is good on the factory stereo circuit? Because it could have been bad and you would have never known because you weren't using that circuit.
07stangcs
Undecided
Houston,TX
Is was factory radio with factory harness. I said screw it and pulled the radio out to test it. Fuses are all good. Croc cliped the positive and negitive on back of radio to battery and the radio is dead. Taking it to dealership tomorrow to trade it out.
Tested Pioneer wired with harness to factory harness and everything works fine. Shaker radio took a shit on me.
