BMR is a reputable company too, and I'm not saying this to badmouth them but they also produce sub frame connectors for our car (as do other companies like UMI), something almost universally regarded as a waste of money on the S197 chassis. Just because they are reputable doesn't mean they wont produce something that serves little to no purpose either intentionally or unintentionally.
Say what ? I installed steeda triangular chromolly tubing type sub frame connector's on my 2010 GT.... bolted and then welded into place. This was done in conjunction with the BMR rear tunnel brace (plus the mating BMR DS safety loop). The BMR rear tunnel brace is 1/4" thick steel plate, 33" wide. When used in conjunction with the pair of steeda triangular sub frame connector's....it forms one homegenous, continuous brace the entire width of the car. The car is then braced from front of each of the LCA mounts.... with other ends of the steeda connector aprx 1.5' forward. The car is then braced front to back...and also side to side.
I also installed the steeda rear STB, welded into place, across the rear shock mounts.....in the trunk, 1/4" above the carpet. I can still flip the trunk floor up to gain full access to the spare tire.
While on a roll, the oem Ford... "A arm brace" (which actually ties the rear of the oem K frame together) was retained, and a BMR real A arm brace (which does tie the A arms together) was installed..... (a few inchs in front of the ford brace). A pair of aprx 14"long steeda tubing braces was installed to re-enforce the front roush sway bar mounts.
The steeda subframe connectors are only 4 lbs each..and easy to install..vs the full size BMR sub frame connectors..that have to be welded into place. BMR lca's, adjustable uca, and lca relocate brackets also installed (middle holes used). Roush street/race suspension installed, and car lowered 1" front and rear. BMR adjustable pan hard bar + mating BMR brace was removed...and replaced with the WL watts link (+ eaton-tru trac differential).
Steeda front stb installed over the roush blower, and also steeda front strut mounts..... (the oem 05-14 car has no camber adjustment).
When the JBA titanium ceramic LT's installed ( + catted JBA catted H section).... I also installed steeda eng mounts...and lowered the eng + auto tranny by 1/4".
Don't tell me that sub frame connectors don't work. The full size BMR sub frame connector's are used by a lot of road race folks. You know when a car is stiff when you jack up the pass side front tire.....and the pass side rear tire also lifts off the ground. Ok, then its stiff.
Did all this stiffening, bracing and welding I had done work ? IMO, it's well worth the effort. The hard core drag racers will use BMR's other version of sub frame connector's.... which use 1.75" tubing from front end of LCA mount..heading forward on the car. For max effect, you bolt and weld em.......ditto with steeda triangular sub frame connectors.
Weld a pair of full size BMR sub frame connector's into place.... then tell us they don't work.
Jimbo
