skwerl
tree hugger
Brian, good luck with the diagnosis, once you have a 12mm compression end, should be pretty easy to remove the springs from #5 if you have access to one of the Freedom Racing Valve Spring tools.
That's what I was thinking. I posted a new thread trying to find whoever was renting out their valve spring tool a while back.
On a more positive note, one of the things I learned on this last dyno run was that my fuel pump duty cycles are at 74%. This tells me that all these huge pumps and injectors are unnecessary for most builds unless you're running E85. I'm using Roush 52lb injectors which are the ones that come stock with a TVS2300, and GT500 fuel pumps with a VMP fuel pump voltage booster. I have plenty of fuel to hit 700rwhp.
