Destination S197
Y'all must have. Some very sensitive hearing. I could never hear the clicking noise unless I was next to a building, divider or in a tunnel...
I can hear mine as long as there is a curb nearby. My city loves curbs too.
mine have done it since I got them last year (I have put thousands of miles on them), I don't think they ever found a fix for it. I also have the slotted/dimpled rotors. your best bet is to get just slotted.
how much you want for them if you put originals back on
Yeah, I got the same BS. ...according to Mike he's sold thousands of the slotted / dimpled rotors and mine were the only ones he ever had an issue with... (-.-)
I sent him a PM Monday night, but havent gotten a response back. I am hoping to exchange for slotted.....
My suggestion for him would be to not sell these or put an obvious disclaimer on them. There is just not an advantage to the dimpled other than cosmetic and the cons overpower the aesthetics.
I've had the same problem since day one. It does get a little annoying since I like to drive with the windows down most of the time. What are you gonna do? I can't afford to just replace them again.
You probably fucked something up when installing then. I had the exact same setup and it wasn't loud at all. Get louder exhaust. It's a Mustang afterall
Thats probably a good idea. Hope you eventually figure out what is causing it, its a very strange issue.
Got my replacement rotors in from Mike yesterday and installed them today. No sounds whatsoever from the slotted rotors.
This is a video I took of the dimpled rotors. The noise was coming from all 4 of them.
Wow that is crazy!
That would drive me insane. Im glad you were able to get them replaced.
I received my replacements yesterday as well. I will install next weekend and have no doubt the slotted only will be quiet.
TPS came through and I really appreciate their effort for myself and several other members.
Thats exactly how mine sound and they've only been on the car 2 months.
When I got mine and there was quite burr on all the dimples. Slot's seemed fine. I probably should have stoned them flat. Mine would click quite a bit when I pressed the brake but not so much when off the brake. One pass down the track and hard braking at 125 mph and the are pretty quiet.
They do look good and have held up well .
Now you see why I threw a fit.
They're a good compromise. I kind of like the looks better of just slotted now that they're on the car.
Mine were on for 1 month and 1,750 miles. That video was taken last week.
As you can see, mine did it regardless if the brake was depressed or not. And I did a lot of hard braking on them and they still clicked.
How did you get them to replace them for you? Mine are starting to drive me nuts, clicking down the highway and then getting louder under braking.
