Steeda strut mount question
bigmd
Any of you guys who have installed these please please post. Did this cure your front end noise as far as the clunking goes? I have them ready to install.
07 procharger
Addicted to modding
Red Deer Alberta
I have the strange 10 way adjustable struts up front...horrible noise coming from them. Sorry I cant speak of the steedas.
BearzGT
Bears Fan
Chicago Western Burbs
Put them in at the same time as the Tokico D-Specs and Steeda Ultra-Lite Springs. Never had any unusual noises in the front suspension. Good quality parts.
RedRide
Vancouver B.C.
I've never had any noise or other troubles from them, installed them from the get-go the first time I messed with my suspension. They've been quiet since 2008.
I never had clunking issues on my 2010 GT.... but the oem GT strut mounts don't allow for any camber adjustment..which drove me nuts. The steeda strut mounts are built like a tank, and allow +/- 1 deg of camber adjustment. ( that's +/- 1 deg of whatever you have to begin with). Mine was -1.1 deg on the pass side..and -1.4 deg on the driver's side. Once the steeda mounts were installed..they are now both set to -1.0 deg........ which is a good compromise between handling and tire wear for a typ street car ( esp with a staggered setup..where you can't rotate). The oem GT strut mounts and also the GT-500 mounts...are both one time use only devices. The latest version GT-500 is the C version..which clunks worse than their previous versions.
I wish I had installed the steeda mounts at the same time the Roush suspension was installed..... instead of having to do it all again..pita.
bigmd
Thanks guys. Pentalab I have the GT 500s too and they are bad. Sometimes it sounds like my frontend is gonna shake itself loose.
Fullboogie
King of the Ski - OG Jr.
Houston
I've not used them, but they are on my list of things to get. The GT500's are driving me crazy.
AlbertD
Tucson, AZ
I used the Steeda HD mounts on my GT and now on the GT500. No clunking noises from the front end whatsoever. Highly recommend them.
bigmd
Well thisnisnall very reassuring . Thanks can't wait to have this noise gone.
eighty6gt
Steeda mounts did nothing for my front end noise, possibly made it worse.
05gtowner
So. Cal
Then you have something else going on. Either you have a bad strut or your install was flubbed. I have the steeda HD mounts and it cured the clunk, creaking and otherwise annoying sounds that were coming from my front end.
eighty6gt
Yeah, different struts are probably in the plans. Next year at this point.
