Sort of.
With two springs with a similar rate (listed rate for the linear, average rate for the progressive), the progressive springs get stiffer as they compress, which makes it so the first bit of travel is a relatively soft rate to better absorb small imperfections. As they compress more, they get into a stiffer part of the spring to tighten things up in corners.
The linear rate springs will often feel more of the initial bump.
Bigger bumps, the linear rate spring will tend to feel less harsh compared to a progressive spring that will transition abruptly from the softer initial rate to the stiffer rate and that can cause a sudden jarring.
For most of the lowering springs for the street market, the difference isn't a big deal as the spring rates for this part of the market are pretty soft compared to the competition oriented stuff.
I prefer the feel of a linear rate spring but for the street lowering springs offerings, it is pretty much a coke vs. pepsi argument.
