Saleen4971
hello everyone!
i've searched here, and other forums, and google. maybe its been discussed before and my powers are failing me, or maybe not.
2006 GT, FRPP axleback and Vortech HO kit (aftercooled, standard boost, diablo tuner and MAFia)
the problem is ONLY in first gear. if you come off the line hard, or modulate the gas/clutch perfectly, no issues. the slightest mismatch (over rev, or otherwise) causes the car to buck wildly. almost feels like its going from 0 to 100% throttle, and back and forth. even if you go WOT while this is going on, the issue persists. only way to stop this violent bucking is to depress the clutch, and then it drives perfectly.
issue only started after vortech install (using vortechs canned tune, stock MAF and MAFia), and only happens in first gear, and only when you dont hit the gas/clutch perfectly.
any thoughts?
any thoughts?
