suspension help! 2011+
mustang_cab
I recently purchased a 2011 gt with the brembo break package. I am interested in lowering the car to eliminate the terrible wheel gap. i plan on using either the steeda ultralight springs or the ford racing k springs. what else is necessarily to maintain proper alignment and ride quality with these springs?
Phuck Phace
Dallas
I went with some Caster Camber plates, Koni Yellows and a Fays2 Watts link. The car handles like a champ now. If you don't want to spend the dough on a Watts link you should at least get an adjustable Panhard bar to correct your rear end after the drop.
N20JUNKY
when we had the K springs on my car we didnt use anything else, I know its probably not recommended but it drove and handled fine just the rear end was off center a bit
Rob72
No Japanese Mustang Here
Baltimore, Marxland
I wouldn't do the springs until I had the dampers also. No sense doing the same job twice. I also would recommend camber plates but there are many people that use camber bolts and have no problems. Its a controversial subject. APH bar and sway bars are good but they can be added later without tearing apart the strut assembly again if you don't have the money now.
BMR Tech
Traction Vendor
Tampa, FL
I recommend the Koni Sports right now, especially since they are on sale for 20% off.
I like both Koni and Tokico, and we have had excellent luck with each. I prefer the Koni's personally.
Flyby763
Jacksonville, FL
I have BMR springs, and panhard bar, and Tokico D-Specs. Depending on where you have the shocks set at it rides just like stock and looks great. I had it aligned without camber bolts or plates at my Ford dealer.
CPRsm
Just swapped in a set of Koni's for a customer. Well worth the money he said. I know they are on the older cars.
