TCS light blinking?
o2sys
Last night I was just out driving and out of no where I see the traction light blink on the instrument cluster and also the tcs off button blink.
It would blink couple times then stop and blink again.
No codes came up with a scanner and after restarting the car it didn't happen again.
Now just curious if it's something going bad?
Boaisy
Dark Knight
Memphis, TN
Could be a speed sensor going off, possibly something with the differential too. When I had my 2004 Impala, sometimes the traction off (whether I toggled it or not) and ABS light would come on and stay on. Only way to clear it was to restart the car. Took it to the dealer I worked at, and they found the left rear speed sensor was going bad. Spent about $80 and replaced the wheel hub on it, and that fixed the issue. Those cars had the sensors built into the hub themselves.
In my Mustang, sometimes when I was accelerating and hitting a bump (happened all the time on an exit ramp on the way home), the car/tire track icon would flash, and the motor would cut the acceleration. Possibly some kind of anti-wheel spin/anti-hop function, though I would drive with the advancetrac all the way off. After the car straightened out, or if I let off the gas a bit, it would resume normal driving.
On the Mustang's the speed sensors are separate from the wheel hub, but the wheel hub can still pose an issue with the ABS system. In the picture below, the teeth on the hub is what the sensor reads (pretty much a binary wave to the computer):
50520
Sometimes if those rings have debris in the crevasses, it can throw the sensor off. I'm not sure how the rear reads for the ABS, but I'm guessing there are ABS rings on the axle (never looked at it closely).
Probably take it to a dealer to see if they can pull any codes/readings from their machine that yours isn't seeing.
o2sys
Thanks Boaisy, I'll have it hooked to a scanner to see which sensor is going bad.
I know that happenes when the car detects slip and sometime going over rough bumps but I was just driving over some smooth roads and it wasn't cutting off the power either.
gray06gt
Could have to do with your wheel and tire combo it did it to me when I had my old tires on it and when I got new tires, cause I needed them, it went away.
