thoughts and help.
whipplebaby
westchester
I have a 2007 mustang gt and right now done to it is
engine:
p1sc procharger kit with gt500 fuel pump and 39lb. injecters at 10 boost
ford racing hot rod cams with lockouts
kooks lontube headers with high flow cats X pipe and mac boomtubes= loud!! but amazing sound and barely any drone:)
drivetrain:
mgw sts
suspension:
eibach springs shocks and struts and rear swaear bar and stock front because of the bigger pulley for procharger it grinds up aganist the front eichbach one
I wanna do wheels and brakes but wanna make alittle over 600 hp for the summer and need help on what to do to make that power new motor and twin disk clutch?? and gears and bigger injecters f1a1 procharger ?? blower cams with new heads what?? and i understand its not cheap and I am prepared but i dont wanna spend a lot! and wanna keep alittle as possible but knowing my motor wont have any problems
monk36
Search the forum. This question has been beat to death. You definitely have a lot ahead of you with those mods you mentioned. Getting that kind of power out of a 3v motor is expensive, time consuming, wrought with pitfalls, pretty cost ineffective, and expensive. Good luck.
engine:
drivetrain:
mgw sts
suspension:
Start with a forged block. After that maybe 127450 or 550 cams and valvesprings. You will also need bigger injectors.
See where you are before adding anything else. I'd think that combo would get you close. The P1 flows 1250cfm which should be enough.
I'm fond of the McLeod RST for a higher hp clutch.
