Throttle body
Domking3465
Texas
Hello I just replaced my throttle body and it keeps throwing it into limp mode. Does anyone know what else could be the problem it would really help and it keeps throwing a lot of codes. For the throttle body
86GT351
Sunny South Florida
Please post a lit of codes. Did you clear the codes and reset everything after replacement?
Domking3465
Texas
Yea sir I did it’s the codes like throttle body limit rmp limit. But if they come up again I will post them. And one of them was force idle I do believe.
Domking3465
Texas
it just started doing again like a week ago and it’s very random when it happened usually when I start the car in the morning, that’s when it happens
StockishS197
Houston
If it happened after the TB install, it’s the TB.
Aftermarket TBs are very hit or miss. You might get lucky, you probably won’t.
Fords ECU tuning in 05+ cars is very sensitive to the TB, so even minor imperfections in the casting, blades or the motors themselves could throw a wrench light.
I would return and get a Ford OEM TB and will likely solve your problem.
Domking3465
Texas
Could I try to fix or clean the original one that was on it before cause it was throwing the same codes when I replace it. The mechanic said I should replace it. But all the codes are the same when it had the oem one. Would that still be cause with the aftermarket one would it still throw all the same codes.
Domking3465
Texas
Ok I got the codes. P2104,F060B,F061B,p2110,p2111,p2135, that’s the codes that pop up
Why was the TB replaced in the first place?
Why cant ppl asking for troubleshooting advice not list what the codes actually mean? Im not looking them up...
86GT351
Sunny South Florida
Especially when there is no specific year or engine listed.
