01yellerCobra
Yes. That's the block I used. I have a stroker crank and rods from another engine I used. The cylinders needed to be bored and honed. But that's needed when going to new pistons anyway. I think it was decked as well. I can't really remember back that far. I don t remember it running more than $200 for the machine work. It might've been cheaper than that. The engine was in my 01 Cobra. So I didn't have to mess with adapters.Great points. Do you have the same Boss block (M-6010-BOSS50)?
If I go with this, will it require expensive machine work, or is it just a cleanup that's needed? What brackets did you need to mount to your engine mounts? I have the Prothanes. Thanks!
Misspelling brought to you by Tapatalk
