ChevyKiller
Preferred Internet Drink
- Joined
- Apr 5, 2007
- Posts
- 6,356
- Reaction score
- 58
At that power level go with a 4R70W good to about 1100 HP.
The TH 400 is beefy & heavy.
I have the Lentech 4R70W with manual valve body & transbrake,i have had it for 2 + years & have made 450 passes with no problems.Call Len & talk to him he holds patents on the 4R70W valve body & has a lifetime deductible warranty on the trans.Tell him you were talking to Randy from Ontario. www.mounceracing.com www.lentechautomotive.com
You are kidding, right? My TH400 is almost 100 lbs lighter than my 4r70 was. (89 lbs)
Both are about the same in regards to you need a disptick, a shifter, Drive shaft, and have to fab a crossmember/brace if you buy a unit already set-up for an S197 (meaning comes with the right bell housing, converter, etc.)
The TH400 is wayyyy stronger than the 4r70 and if you are going to go to the track every now and then and mostly drive on the street - I would go with the 4r70 with an OD. If you are going to beat the shit out of it at the track - go with the TH400 and save yourself headaches to come. I broke the 4r70 3 times and have not yet had a hint of damage to this TH400 and I'm running in the 8's at 160 mph. I was breaking the 4r70 with far less power than I'm pushing now. I also had tremendous overheating issues standing on the trans brake on the 4r70. If you stand on the brake with the 4r70 - those things get smokin' real quick. The TH400 is a far better 'drag' trans but I prefer the 4r70 for the street easy over. You'll want to have that OD on the highway - believe me.
As always, it comes down to want you want - a street car or a race car. I have learned the hard lesson over the years that you just can't have both - no matter what anyone tells you or tries to sell you - you can't have both, believe me.
