JTallon08GT
- Joined
- Jan 16, 2012
- Posts
- 82
- Reaction score
- 0
So i decided to change out my clutch and install a new one. I have done this before many times. So here is what i have going on.
I have removed the exhaust h pipe, i have removed the drive shaft, and intake.
I then removed the battery, took out the starter, removed the shift link all sensors and wires. I then removed support beam for the transmission and held it in place with a transmission jack.
I then placed a jack against the k-member, and took out the 2 nuts on either side by the struts, and both bolts on either side by the floor boards.
I then placed a jack with wood on the oil pan and then and then with the two jacks lowered the engine and trans together about 7 inches.
I then lowered just the transmission to lean it back, i removed all 7 transmission bolts (this is how many there are right?)
there was 2 on the top, 3 on the driver side, and 2 on the passenger side.
After that i am stuck, i cannot get the tranny off, it is NOT hitting the headers or the tunnel. i literally cant get it apart from the engine block at all.
After jacking the back of the tranny up and lowering it just a little, i have a gap on the top between the transmission and block just enough to fit a quarter, or nickel.
I have been trying and i cant do it, am i missing something here? Do i need to get a pry bar with a flat head on it and pry?
Any help would be greatly appreciated.
-Jeff
-Jeff
