You will need a misc shim pack as nitrostang said, to shim it correctly or what I think is the easiest way, install the new bellhousing without any shims. place dial indicator on both the MS and CS and take end play measurements, get a shim that gives you the required tolerance put it in, and then check again. You should have between .001"-.005" end play on both the MS and CS. Before you take the measurement though, spin the input shaft over a few times and lightly tap on it once or twice with a soft blow mallet it will seat everything to get a true reading, do the same after the shims are installed before taking end play measurements.
