Tremec 3650 Bellhousing
Born To Run
Woodstock,Ontario
2005 gt Tremec 3650.
Can just the Bellhousing be replaced easily,or does trans need complete disassembly?
Nothing in search.
86GT351
Sunny South Florida
Replacing the Bell Housing is not hard once the transmission is out of the car. Most important thing to do is make sure the Input Shaft and Cluster Shaft are shimmed properly.
Born To Run
Woodstock,Ontario
3650
It is out of car,how do I know what that the input shaft & cluster shaft are shimmed properly.What do I look for? Where are these shims located?
86GT351
Sunny South Florida
The shims will be located inside the bellhousing. There will be 2 Bearing Cups with Races in them. The shims go under the race. As for proper shimming, it is a very critical thing. Too loose can cause issues. Too tight can bun things up.
Call Promotion Powertrain at 954-771-5575 and speak with Ricky. Migt be able to help you out with a misc shim pack.
BeachMonkey100
Myrtle Beach, SC
You will need a misc shim pack as nitrostang said, to shim it correctly or what I think is the easiest way, install the new bellhousing without any shims. place dial indicator on both the MS and CS and take end play measurements, get a shim that gives you the required tolerance put it in, and then check again. You should have between .001"-.005" end play on both the MS and CS. Before you take the measurement though, spin the input shaft over a few times and lightly tap on it once or twice with a soft blow mallet it will seat everything to get a true reading, do the same after the shims are installed before taking end play measurements.
Born To Run
Woodstock,Ontario
Tremec 3650
Why would I need to re shim if I am just replacing the forward front bell housing.I take it off as it is cracked & put on the exact same replacement part?
skwerl
tree hugger
central Florida
On the 3650 the bell housing is part of the case. You would need to transfer the entire transmission from the cracked case to a new case.
BeachMonkey100
Myrtle Beach, SC
Just like skwerl said, it's not your normal bell housing that you can swap for a different motor or such, the bell housing is part of the transmission. It's not as difficult as it may seem though, if you're just swapping housings. pull one housing, remove shims, replace housing, check end play and shim accordingly.
Born To Run
Woodstock,Ontario
3650
Holy fuck,it's built just like a women & I don't understand them either.
Tremec is a Latin word for women.
Well like I told my 2nd wife,I will give it a try,thanks guys.
Roush_54
I actually just did this a couple of months ago ... my brother dropped my trans and it cracked pretty bad. its not as hard as it looks... I just stood it right up unscrewed the screws took of the throw out bearing and it pooped right off... made sure not to touch anything on the inside...lol sealed it right back up with silicone and screwed the new bellhousing in ...let it dry up and replaced my fluid will the tranny was out.... so far I have over 10k miles and it shifts better than ever...wish I had pics to show you but its actually pretty simple...
DiMora
More Is Better
Fayetteville, GA
I think you can indeed unbolt just the bellhousing on the 3650. It is not installed two-piece like a T56, but it does come apart.
86GT351
Sunny South Florida
Because a different Bell Housing is a different casting and there is no guarantee that it is 100% the same.
Born To Run
Woodstock,Ontario
Bell housing
I got it done,took it to local tranny shop & watched & learned.The shims were the same on the donor transmission as mine.I have 1000 miles on it,so far so good.
Thanks
86GT351
Sunny South Florida
Thanks
OK. Gld it worked out for you. Every trans is different so it just worked out tht way for you.
