302
Sad day for the mustang...
I should have kept my '08 and threw a hellion on it.
And just for lulz, sig change ftw.
So wait Ford has a TSB about any performance additions to the Mustang. Is this the same car Ford spends all this money advertising revving,drifting around corners, filling their catalogs with performance parts for. Guess I should trade mine in on a new Fiesta
Yea, same car shown in a burnout poster in the dealership too.
close, but i disagree to an extent. in the TSB "clutch damage" is listed as one of the items to look for as an indication of an over-revved motor. so now they have their excuse (in writing) to void a warranty on a stock car that was driven hardIt's not like that. They're not saying you can't drive it hard, they're not saying you can't modify it. They're just saying, if you modify your car with aftermarket parts, and aftermarket tunes, and that modification damages your engine, they're not going to pay for it. It's no different than it's ever been, except this time they're really paying attention.
Do whatever you want to your car, but if you blow it up because of an aftermarket part, don't expect Ford to pay for it. That's really all it is.
guys check the troubleshooting diagram in the TSB
if i understood it correctly, according to that diagram, if your battery was ever disconnected (say to get the damn thing replaced) and for one reason or another you have P1000 DTC, that's grounds to "initiate warranty cancellation process"
notice how other circumstances could lead to one step that requires finding mods that could explain the failure.
but the one unique combination of P1000 + Battery disconnected goes straight to the warranty cancellation box..
unless the diagram is flawed
correct. and if they pull the tranny and the clutch is "damaged" then they have their proof.not true, they still need to PROVE it. It us up to the service department to PROVE thats what happened.
I think that's on the extreme end of things. And clutch damage is different than clutch wear or the known clutch issues. If you destroy a clutch it's not because you powered up an on-ramp a little fast. It's from some form of abuse. You shouldn't expect Ford to honor their warranty because you decided to launch off the factory rev limiter at the track with slicks. The user (owner of the car) needs to accept some liability as well. The car is not bullet proof and should be driven with some responsibility.
agreed.I think that's on the extreme end of things. And clutch damage is different than clutch wear or the known clutch issues. If you destroy a clutch it's not because you powered up an on-ramp a little fast. It's from some form of abuse. You shouldn't expect Ford to honor their warranty because you decided to launch off the factory rev limiter at the track with slicks. The user (owner of the car) needs to accept some liability as well. The car is not bullet proof and should be driven with some responsibility.
and "damaged" doesnt necessary have to mean broken discs and pressure plates...im sure excessive wear would qualify too.
we're all gambling now...and the odds are in favor of the house.
i see what youre saying. makes sensethat is incorrect
they need to prove that OVERREVVING the motor CAUSED the damage to the clutch, then they can void the warranty. Id love to see them try to prove that.
isn't P1000 just a readiness code and you have to drive a few hundred miles to clear it?
