s8v4o
- Joined
- May 18, 2007
- Posts
- 3,476
- Reaction score
- 10
I know ideally 3.55's or 3.73's are considered good turbo gear because they "load" the car well but I'm curious as to who's running 4.10's? I know the S197 is fairly heavy so I thought 4.10's might not be that bad. When I load the numbers for a 28" tall tire, 4.10 gears, and of course 4th gear I come up with close to 122MPH.
So how many turbo guys are running 4.10 gears? Do you like them or do you want to change your gear. For those running different gears have you thought about stepping up? My calculations for 3.73 puts trapping in 4th gear at close to 134MPH at 6000RPM. I guess that's fine if you're putting out over 650HP.
The reason I'm asking is because I want to go as fast as possible (within reason) N/A. Then see what numbers I can get with the nitrous kit I just installed. While working my way up to a turbo kit. I'm trying to choose my future mods wisely so they can be good for me now and later when I have a turbo kit. That's the reason behind me asking about the 4.10 gear and turbos.
