UMI stuff ROCKS !!
silverstangz
Clermont, fl
Just returned home from vaction/doing some auto-x, and before going, I installed {finally} UMI adj Uca, non-adj lca, and bolt in subframe coonectors, and they are amazing !!!! car felt so much better !!!! and being only my 2nd time doing auto-x I am now offically HOOKED!!!!!, just wanted to say thanks UMI for such a great product .
GRAYPNY
Rich
NorCal - Chico
I will be selling a set of UMI lower control arms next week. Poly bushings chassis and spherical on the axle. Just too much noise for my taste. FYI
LegendLives
South Central, PA
I just installed UMI lower control arms w/ the relocation brackets today, got the 15% off over the 4th of July. Just need to go to drag strip to put them to the test.
Glad you like your set up silverstangz.
dagamore
Poor Driver mod
K-town Germany
I am very happy with the UMI stuff on my car right now(anti-hop+upper rear control arm) a little more noise, but not bad, and makes the car squat like i wanted it to.
UMI Sales
Philipsburg, Pa
Hello
Thanks Everyone for the great comments....It is really good to hear that you are satisfied with the quality and performance of our products. And if you are looking for maximum chassis strength then a set of SFC's are the way to go for sure. They not only help with weight transfer but they also help keep the body panels from getting stress cracks and dimples. If you have any other questions feel free to ask.
Thanks Again Everyone for the support.
Brad :D
UMI Sales
Philipsburg, Pa
Hello
Thanks for the great comment and considering UMI Performance. We really appreciate it and when you are ready feel free to give me a call and I will be more than glad to help.
Thanks
Brad :D
kevinatfms
EX-ford tech(6 years)
MD
i have every bolt on piece they sell and i love them all. great prices and they fit well.
Corpo
I
Red Deer, AB
well... i ordered some weld in lca relocation brackets, everything looked good out of the box however i started bolting them in and the little metal sleeve that your suppost to use as a spacer where your LCA was, well it was too small of a diameter for the stock bolt (or supplied bolt) to fit through. so the design to just bolt in and weld in place without a alignment went out the window.
i went and found a bolt that would fit through the sleeve, but because the bolt holes in the frame and bracket were for a larger bolt there was enough play to shift the bottom of the bracket about a cm or so forward or back.
i pushed it forward to its maximum amout of play and welded them in like that. drives straight so it worked for me.
oh yeah, and it didn't have instructions in the box.
UMI Sales
Philipsburg, Pa
Hello
Sorry to hear about the inconvenience of not getting the instructions and the correct hardware as well. If you can PM me your full name and address I will be more than glad to look into your order and get you replacement/correct hardware that is needed. Once again sorry for any inconvenience and thanks again for choosing UMI Performance.
Thanks
Brad :D
