Uneven Tire Wear
GoFaster06
On both my track & street tires I've noticed that the rear P/S tire is wearing more on the outside of the tire. Plan on taking it in to shop for further investigation but I want your guys input as to what could be causing this to happen.
GoFaster06
Can camber be adjusted on the rear, because that is where the problem is?
REAR P/S tire, not front.
19COBRA93
Ford Racing
Clinton, Ut
Bent axle tube is about the only thing that can cause that. And it's more likely a tow-in issue on that side. Is your tire/wheel centered in the wheel well? Has the car ever been wrecked? Gone off the road? Hit a curb? Anything like that?
GoFaster06
Yes, the car has been in an accident, hydroplanned off road & only had front end damage that was repaired.
19COBRA93
Ford Racing
Clinton, Ut
I've seen it from time to time. It's fairly easy to repair. Unfortunately you'll have to remove the whole rearend to do it, but once it's out it's not a huge deal to fix.
