Why yes, I did.Don't you have a construction crew to photograph or something???
So does anyone have these rims ordered and installed on the car in the non painted version? Has anyone been daily driving them for a while? Whats performance like?
Rims & wheels work great,everyone likes them alot.Personally i am not a wheel & rim guy.
No spacers needed.
You must remove or bend the bracket up that would hold your rear sway bar,no big deal.When balancing the wheel,the wheel weights(if stick on ones) must go on the inner lip of the rim & use foil tape to help hold them on.
Here is a pic,let me know if you need more info.
And you can Daily Drive on these rims? Whats tires are you running? Do you have any pictures of the car just sitting on the rims?
What year of car is this on? Others have had luck with the Jegs wheels but I tried them on my 05 & they hit the calipers. The calipers have changed over the years & even in the same years. I would hate to buy them & find they do not fit. Thanks.
Hey Born, anyway you could snap a couple of pics of where the weights are placed?
I wouldn't mind seeing some more pics close up on some cars with these wheels...
Its an 2005 GT.On the front the clearance to the caliper is 3 sheets of paper thick.The rears are not as bad.
Let me clarify,i did have to remove the plastic dust cover on the rear shocks & the metal do hicky thing spot welded to the frame behind the rear tire,i think its for flat bed towing tie offs??
Nothing serious,it was all dead weight anyway.
I will get some pics up Thursady,had tooth out today & the perkasettylonol3advil are starting to kick ins,seeya.
