8.6-8.7:1
They list that for the 5.4, 9.08:1 for the 4.6. I can see a tad lower due to the .020 overbore? I run stock bore 15cc diamonds.
http://www.modmaxracing.com/product-p/dia30066.htm
That due to the .020 overbore? I run stock bore 15cc diamonds.
As you edited your post.
Check the Diamond parts catalog. http://www.diamondracing.net/pdf/Ford-Section.pdf
They list it at 8.7.
I think the numbers are probably optimistic from the dyno in all honesty but we all know how that goes from dyno to dyno. The fuel system shows to be about 92% utilized so we have room to play but not really much need to do so as even on 16psi the car spins @ 100mph sometimes when the weather is in 50's.
Its not the fastest out there but makes a really fun street car with wide power band to play in and spools quick. Even the lower compression isn't much of a bother with the cams locked out thing comes in hard and quick.
I've read in a tech article here that once the injector duty cycle reaches 90-92%, there is nothing more left in it. But if you aren't going lean I suppose it's nothing to worry about.
And 100mph burnouts?
Looks like diamonds catalog now has 45cc, 51cc and 55cc. So they are assuming max variance looks like,I always used 49.6cc in the calc.
Ford service manual gives a range:
Combustion chamber volume 48.1-51.1 cc (2.94-3.12 cu)
So long as it goes straight. The thing with a good tire on it will blister it in 1st and 2nd. I know if I could WOT shift and tranny hold it one pass it would go into 10's
I'm hoping you have a few numbers that I'd be interested in.
Do you know the commanded rail psi and fuel pump duty cycle at max rpm? The 405 is something I've thought about doing if I go forced induction (again) in the future.
Bruce you got a pm.
