vortech pulleys procharger pulleys
The sizes are very different as I recall.
bullitt boy
NJ
I have a couple of diameters just wondering if the shaft / keyway area is the same. I have the stock pulley on the PC now and don't want to crack the "if removed warranty is dead cap" to find out
05stroker
Never enough power guy!
Bullard Tx.
More info on the warning?
If you measure the Vortech pulleys I can measure my Procharger if you like.
bullitt boy
NJ
20 M/M or 27/32nds inches inside dia where the shaft gos with a keyway aprox 4mm x 2 mm or 3/16 x 1/16 running the length of the hole.
bullitt boy
NJ
there is a tamper proof cap over the pulley bolt that automatically breaks when removed. If this cap is removed the warranty is void or so I've heard.
