Weou09
Those are nice. Not sure I would do a 2618 piston in a car driven as much as yours though
I don't think you will have any issues running a 2618 pistons, you will just have to let the car warm up a bit before driving maybe.
If you want a flat top then I would look at these Wiescos. Too bad your machinist already took the block .020 over because these come in a .010 over and a .030 over. I had the same problem with the cp/saleen pistons, just didn't quite have enough room to make them work. I bet it probably would have worked .010 over though if it was close with the cp/saleens. Anyway, here are the Wiescos. They also come with coated skirts and rings at this price.
http://www.modmaxracing.com/product_p/wisk430m905.htm
If you really wanted to push it you could use these. I have wanted to do a BB with these, but it would be a little higher than 11:1.
http://www.modmaxracing.com/product_p/wisk0010m905.htm
Or these Ross pistons that also come with rings and would give stock cr. There are a lot of options for stock cr.
http://www.modmaxracing.com/product_p/ros99629.htm
The rest of the pistons don't come with rings though so you have to take that into account. I believe the Modmax Moly Rings are around $120 by themselves.
I don't see why they wouldn't work, but it is just like you stated, they are the top end of the price spectrum.
Ross w/ Rings $699 (9.8:1)
Wiesco w/ Rings $775 (11:1)
CP w/ Rings $912 (11:1)
It is up to you, I believe they are all good pistons. It's a budjet engine right? My thought would be why pay extra for a piston that comes with upgraded wrist pins and the works when you are still using a stock crank?
