Dark_horse
Nice work my my friend... what are you maf counts at 5k? Just curious....
Don't believe you. Gonna need some videos to confirm.
Pegs out at 1030 if it's stock...
How many lbs of boost are you at...it's probably good for a couple more
Wow, on 9ish lb at 6k I still had room with the stock meter and mafia. I'd think an HPX would be good for your goals.
I'm thinking I'm going to have to go HPX-E too.
e-85 killin it!
RJ, have you wired up your second pump on a source yet or are you just running both full time? I've talked it over with Jeremy and I think I'm going to run a AEM e-85 320 pump full time as the primary as an attempt to keep temps down street driving it. Then with fc3 controller wire my aux out of the eboost2 into that for the walbaro 465.....thinking 2psi turn on..
What type of return are you using? I'm going to run the same setup as the gt500, dead head, regulator before rails so there is less heat put into the return fuel.
