Infamous05
Rod run was a dissapointment this year. Did anyone else get charged to park? The owner of one of the go cart places tried to charge me 10.00 to park in their lot. I think I only spent 2 -3 hours total
how is the hp are u scared of it blowing up cause I think u are in the unsafe zone but I could be wrong. just woundering if u have stock bottem end of u have rods and all that!?
To be honest there really isn't a "safe" number on these 3 valves, the safety is relative to the tune. There have been motors go at numbers as low as 400hp at the wheels and then there have been at least a few cars survive several years at 550hp at the wheels, and then of course you have the "factory freak" that was dyno'd all the way up to 819 at the wheels (link below) with bone stock internals! Of course those were dyno runs where the load is simulated and not actual, but still... That's crazy impressive!
General rule of thumb is stay at or below 10lbs of boost with low timing and a good fat Air/Fuel ratio and you'll be fine. Oh and don't spin it above 6k like its N/A, it probably won't take to much of that lol. Best thing to do is get an N2MB wot box so you can set the global rev limiter at 6k and not worry about it. All the factory limiters (ie traction control and rev limiter) cut fuel instead of spark which is hard on a FI motor, just another thing to consider when making a decision on the wot box:thumbup:
http://www.s197forum.com/forum/showthread.php?t=96792
Yup I agree with all of this ^^
Heres some pics a local guy got at Cars and Coffee on Saturday
man that looks good
Sweet pictures!
The filter came with the kit and I used the small 90 degree elbow, a metal hose junction, some extra 3/8 line rated for trans fluid and hose clampsHay where did u get the filter? And what did u use the relocate the steering fluid tank
RJ, you've got the breathers I see so where is the other end of this connected to?
John, it goes to the blowoff valve and boost gauge. In this pic you can see where it tees off to the boost gauge and then the other end continues to the blowoff
Awesome, thanks RJ. Might have to get with Greg and Jeremy for those now! LOL
Cleaning up for Mustang Week!
Still have to do the fender wells and a lot lot more! Plan on doing some minor paint to get the RIDS I left before and do the Blacklight, V7 combo. Wipe down the rear suspension parts and some other small stuff.
What did u use to clean the inside of the wheels?
