HitandRunDriver
Amateur Goon
It's acid based...not sure how strong but I would feel a bit iffy using it on paint
I picked some of this up on Friday along with some clay lube and chemical guys citrus wash for when I detail. I detailed my dad's Lexus for fathers day and I was pissed when I couldn't get some nasty water marks out of his hood even with an orange pad, Wolfgang total swirl removed and my porter cable 7424. My thought is to go back and hit the hood with this stuff and see if it'll get them off. It comes in tomorrow so it'll be this weekend's project. My question to you guys is can I use my porter cable with this stuff at a low speed with an orange or yellow pad? Or should I stick to going it by hand to be safe?
Sounds like the water spots are etched into the paint. Usually, water spots are nothing with an orange pad and a decent cut compound. What year Lexus? I detailed my brothers 95 Gt and it had some nasty water spot etching. I used an orange pad and some Menzerna compound and it just took a little more work then other areas. You may just need something with a little more cut, what compound/polish are you using? Check out how it rates on the compound chart at the top of the page.
I'm guessing the Lexus has what Mike here calls type 2 water spots:
http://www.autogeekonline.net/forum/how-articles/29134-how-remove-water-spots-hand.html
yeah they look to be stage 2 spots. I'll give it a shot with the water spot remover and if that's not enough I may try distilled vinegar.
