What causes this? I bought new tires and was pulling the wheels off today to drop them off and have the new tires mounted. I noticed the inside edge of the front tires was rounded off as you can (kinda) see in the pic below (right side is inside tread). They looked pretty evenly worn other than that.
I put BMR 1.5" springs on the car a couple years ago, along with Koni STR.T shocks/struts and new strut mounts (they were supposed to be GT500 mounts but they might just be new OEM). I was told I did not need camber bolts so I don't have them. I had the car aligned after I did all the suspension work. What do I need to fix?
