Weird plastic burning smell - never had this happen before
2009 Deluxe GT
Livingston County Michigan
So I finally got my 09' out of storage a week or so ago and took it out yesterday for about the third time. I store it in an enclosed car bag so nothing animals can make it in over the winter. After the first time driving it I thought I noticed a weird burning type smell. Then the second and third time as well. I started to get really worried like maybe I forgot to take one of the dessicant packs out from under the hood when I got it out of the bag but couldn't see anything anywhere under there.
Next I jacked it up to take a look underneath. Lo and behold, on the bottom and inside of the drivers side exhaust pipe between the cat and the H connection in the middle is what looks like white melted plastic! Wire brush wouldn't touch it, nor would it scrape off with a screwdriver. Had to use a box cutter type knife blade to scrape it off a little at a time. It didn't come off easy at all!
So best I can figure out is that on my first time out I ran over a plastic bag and it stuck and melted to the exhaust. Does that sound possible? Has anybody ever heard of such a thing?
Yup. Used to see that complaint a lot.
WNYGT5-0
DogTown, NY
Omfg I would be pissed.... I wil not run bags or debris over. I’ve had a grocery bag wadded up in the serpentine before. No bueno...
Jgt58
Been there. Behind a truck and a plastic tarp flee out and I couldn't avoid it. Took forever to get the melted plastic off the exhaust.
Macman45
Resident Geriatric
Atlanta / Bay Area
I, like an idiot, left the Pypes sticker on and it nuked to the exhaust pipe. Anyone have a good method to remove the hardened plastic? Wire wheel? No “solvent” will touch it
07 Boss
Sin City
My exhaust seems to catch everything. It’ll always get hung up on a clamp bolt or sensor but I still have chunks of plastic stuck on there.
WJBertrand
BTDT, even if you're able to scrape most of it off it'll continue to stink for weeks, especially if you park in a garage. Not too much can be done but to let it slowly burn off.
Happened a few times over the years. I just pull as much as I can off and let the rest burn off.
crjackson
Midgard
Wife did that in her 2014 Track-Pack. Took me a couple of days to realize what happened. Then a week later, I did the same thing in my 2014 Track-Pack.
I have since read dozens of posts by others having the same issue.
Welcome to the club ;)
oldyella
My Pypes exhaust caught a Walmart sack last fall and it smelt like Chernoble for 2 months or so. I STILL have the black molten lava pasted to the side of the pipe. It's so petrified now that it no longer omits toxic waste scent.
