weld prostars fitment
Jperezav2009
Quick question guys I have someone who is selling me the following for quite cheap but wanted some recommendations. Would also like to know if they will fit a 06 gt.
WELD Prostars
15X3.5 FRONTS
15X10 BACKSPACING 5.5 REARS
THEY WERE ON A 1990 MUSTANG COUPE
let me know guys. Not to sure if they clear my stock brake calipers
retfr8flyr
The Old One
Providence Forge, VA
You have to be shitting me, you put this in tech. The fucking search button must be broken again. There is a fucking sticky in the TIRES AND WHEELS section that answers all your questions. NO they wont fit.
Earl
The Big Herm
Build in Progress
Valparaiso, IN
Ford used several different sized calipers between 05 and 09. I ran the prostars before I got my bogarts. The issue wasn't the calipers on mine but the shock mount/sway bar mount area. You can get a wheel spacer to clear and I believe keep your sway bar (someone correct if i am wrong) but you will require longer wheel studs as well as they are very thick rims around your hub. This is for the rear. I never ran prostar fronts
Search function works wonders
Sent from my SAMSUNG-SGH-I717 using Tapatalk 2
downtime!
IAMKONABLUE
Keller, TX
That back spacing on the rear is a little shallow. 10" wheels for our cars usually have 7.5" back spacing.
NotQuik
I can't drive
Central Florida
I ran 15x3.5 prostars up front but had to utilize a half inch spacer and remove the sticky weights.
The rear 15x10's I had with 6.5" back spacing (from another mustang I had at the time) didn't clear the calipers.
perfect fitment - throw them on and immediately go WOT!!
:thud:
