Weld Racing Weldstar RT
saleen07gt
St. Petersburg, Fl
SOLD !Up for sale are my 2 Weld RT rims, black anodized 15x10 7.5 backspacing worked perfect on my 07. Tires are Mickey Thompson ET Streets with literaly three 1/4 mile passes before I bent a driveshaft. These wheels hooked perfectly at the strip at 4000, 4500 and 5000 rpm launches. To buy this set up would cost about $1300 but I'll let them go for $800. Lug nuts included. :roflmao:
saleen07gt
St. Petersburg, Fl
The bolt pattern is standard for the S197, I think its 4.5". To run 15"rims in the rear, you need to trim a little metal off the bottom of a bracket, I believe its where the bottom of the shock mounts and buy a relocation kit for the rear sway bar. The extra sidewall of 15" tires really help the car to hook up.
Born To Run
Woodstock,Ontario
Weld RT rims
I will search and post tonight, they were on a black car and looked great. Seen these wheels on a silver, red and yellow stang and looked awesome.
Here you go,I have had them for years,you will not be disappointed.
If I remember these rims are dot approved!
Born To Run
Woodstock,Ontario
Weld RT rims
Just bend the bracket up as I did in this pic,I run without a rear sway bar.
Tire size?
Bump for some killer rims. I upgraded to these same wheels after getting tired of the crappy Race Star uni-lugs. Weld makes some top notch stuff. These will clear the brakes but you will need the sway bar relocation brackets as mentioned above. Cheap and easy, it's about a 10-15 minute mod once you have the car secured on jack stands.
Born To Run
Woodstock,Ontario
Tire size?
Mine 28 x 10.5 x 15,his for sale are 26 x 11.5 x 15.
