I have the 3v, however one would think that because the main diffrence between the coyote and 3v rears is the gears the better question should be at what 60' should I consider welding the axle tubes?
a 1.6 60' hooking in a 3400 lb car is the same amount of force whether a 3v or a coyote is pushing it.
Not necessarily. It is actually a little more complicated than that. You can have a 600 HP vehicle, spinning tires, cutting a 1.6 and a 300 HP car dead hooking, cutting a 1.60.
Correct, if the cars weigh the same, the force required to move that vehicle from 0mph to 60mph is similar - yet the effect on the rear axle is substantially different.
Twisted axle tubes actually seem to appear on higher powered cars, with drag radials. It does happen on aggressive slick cars, too.....but is most likely to happen on a "lesser" hooking car.
When tires play the game of hooking, spinning, hooking - in succession, that is the worst possible scenario for the parts on a vehicle. The shock from this is greater than a slick car launching at 7K RPM and dead hooking. The reason is, if you have a wheel spinning 70mph, but the car is only moving 20mph....when the tire does gain traction, the load is tremendous on the drivetrain and rear axle components.
We used to, years ago, base our recommendations (welding, etc) on sixty-foot times - but the only way you can do that is if every single car get's to the sixty foot beam in the same exact manner; impossible.
Never thought about it, has there been problems with the relocation brackets twisting and/or breaking off??
You are fine. We have not had a single incident/failure/bend/break with the (3) hole brackets that we have been shipping for years now.
The older (2) hole design was not as strong - and really needed to be welded on a drag racing application. But, even then, I have seen improper welds lead to failures. We would have people weld their brackets in, race the car, have a weld fail - causing the entire bracket to damage, and call us to say our brackets broke - when it was the weld separating that caused the bracket to bend/break/crack.
Enter 2010 - the year we completely re-engineered our CAB005 Brackets. Tested, tried and true on hundreds of <1.4 sixty foot passes, MANY 1.3's....and can even claim low 1.30's - bolted, not welded.
