CPRsm
- Joined
- Jul 11, 2011
- Posts
- 3,043
- Reaction score
- 1
No problem man. I never mind some spirited disagreements. There are a few misnomers in your posts though. I think if you read or ask any chassis shop they will tell you the same.I disagree. You want the LCA to be in a downward angle from body to axle housing. Ford sends them out with the LCA level to slightly up. This is better for ride quality but causes the dreaded wheel hop. The body will actually lift over the axle and bounce on the springs under torque. Dropping the LCA allows the weight of the body to actually drive the rearend housing down. This becomes even more important with DRs and slicks. I've followed your treads here and on SVTP. I am by no means trying to school you on the use of LCA relocation brackets, your in the business of go fast goodies. But in my opinion they are useful in the stock aplication as well. With the amount of torque these things make along with a 9.5" wide tire, we need all the support we can to plant this thing's ass.
BJ
The angle up definitely causes the body separation. Which is a good thing. That is what drives the rear end into the ground and there by the tires. But what really causes the hop is the over extension, and even more so the bushings caving in and bouncing back in the lowers. It's a problem in leaf spring cars also. The front of the leafs wrap up from the pinion rotating up until they can't go any more, and then they unwind and cause wheel hop when the snap back down.
The arm point down only gives the illusion of more weight transfer. Instead of the rear end coming out of the car, it is actually sucking up into it, causing the car to dip in the back. The only guys that really do this are high HP guys trying to get a touch of tire speed before the tires shake. When the rear end goes up in the car, it is taking weight off the tires, and does not really apply weight to the tire until the spring are fully compress and pushing on the rear end again.
By default the angle up causes the hop because it is pushing into a wall that won't move. Pointing down it just kinda rotates without any real action to push forward, so there is no push back, no hop.
Fuck, Seer's been jacked again. I owe him two turbo kits now.
