What am I doing wrong?
13726548
GA
I believe these engines run out of steam at about 5800rpm. So 6k+ shifts sound a bit high?
mwinter501
Again, sorry for the ignorance, but what do you mean by me seeing some seat? Thanks everyone for the help, need to brush up on my lingo.
GT.350-R
3PEDLS
Portland IN.
Sorry I type to fast. I meant to say (seat time) . These car are different from our old fox cars. It just takes practice
mwinter501
Do yawl think I should be launching at higher RPMs or do I need taller, stickier tires before i try that? It really seems like I could reach farther into the rpm range when launching, traction has never been a problem since I got the nittos, but I know there are better tires.
GT.350-R
3PEDLS
Portland IN.
I'm not sure how tall your tire is now but with 4:10s at our power level I wouldn't go any taller than a 26 inch tall tire.
Mabey someone else could chime in on this but when I ran in florida a month ago my car would only trap @107 and when I got home in Indiana my trap speed went back up to 112mph.
I'd say we're at the same power level just different air,temp and altitude
mwinter501
Thanks for all of the help. I'll start power shifting and hitting more test and tune nights. Hopefully I'll get the times down a little. Thinking back, i was going against challenger SRTs that were dialed in at 13.00. So a small fraction may be the local climate.
psfracer
billy badass
Valencia, CA
Here are my thoughts after reading through the thread.
1) even though the altitude is only 650, which isn't bad, a high humidity can really increase the DA, which will effect ET/MPH.
2) If you look at the ET spreadsheet here: http://s197forum.com/forum/showthread.php?t=5218 You will notice that most people trapping around 104-105 mph are turning very low 13.1Xs or so., but also notice their 60' times are in the 1.9X range. You have a not to bad 1.8X 60' time, so it could be you just need to be more aggressive shifting. But at your power level, I think a 1.8X 60' time isn't that bad--its actually pretty good.
3) One way to see if the car is laying down is to compare your 1/8th mph to your 1/4 mph. You are at 22 mph---most cars in your ET range, N/A average about the same 22-23 mph---so the good news is it doesn't look like the car is pulling timing or getting heat soaked or anything like that.
stang72
Family of Stangs
tennessee
I am running similar mods to you.Also launch at 4500.Fully stock suspension except for the bmr LCA's.Removed front sway bar and running on 275-40-17 m/t dr.Good for 1.73 60ft.
rojizostang
i love my cams
san antonio, texas
i agree...with psfracer...if you have 4.10's, stick with a 26" tall tire. i have 4.56's and still run a 26" tall tire. if you've got a 5m (manual tranny), imho bias ply et streets are a better choice than drag radials. the sweet spot for launching (at least in my experience) is a lot wider. with a harder launch, bias ply streets, front sway bar removal, i think you could see 12.8's or 12.7's. but you gotta powershift!
mwinter501
I went with UMI single adjustable LCAs.
PSFRACER: that's all good news, I'll focus on shifting more aggressively and see how much I can pick up. Although my times seem slow, they do still fall in line with other cars at the local track. I just started getting concerned seeing consistent postings of similarly modded cars almost going a full second faster. Sometimes I forget to take humidity into consideration since it's always so humid.
mwinter501
Rojizostang: seems the general consensus is for me to start powershifting, so that is first on my list. I found that I need to go slow with the way I change things up with drag racing. If I go up to the line with more than one or two things to change, I usually don't end up doing any of them once the lights start counting down.
Hopefully the shifting and LCAs make a notable difference. If not inwill certainly start looking at bias ply tires based on your recommendation.
Thanks again everyone for the help. I greatly appreciate it.
fdjizm
Drag Queen
NY/NJ
No that's a myth, you shift higher to be in the better part of the powerband for the next gear.
My engine doesn't stop making HP till 6200 then it slowly goes down maybe 5-8hp till I shift at 6500.
Just because you're done making HP doesn't mean it's time to shift. :beer:
