tagle281
I currently have 295 35 R20 on 20x10 Razors. As you can see they are a bit too big. What sizes do you recommend?
The middle number is the profile height expressed as a percentage of width. So the 295/35-20 has a profile that is 35% of 295. If the tire is too tall but you wish to keep the same width, go to a 295/30-20.
I have 295-35's on a 10" wheel and think they look fine.
Alot had to do with brand also because not every tire is the same even though the numbers say so. What tires are you running. I'm running invos in the back. It may just be the way the tire is designed.
