Alfiedagr8
The reason I said above .7 is because between .3 and .7 in ur cruise and slight tip in Removing timing from here will make ur car feel sluggish around normal city driving.
Ok what i do and suggest is simply forget MBT it MKT is lower anyways at WOT than MBT. And some tables are different so becareful on the last not when he said on top. My table and sofware show WOT on the lower end of the graph. Anyways. Just remove 3 deg from .7 to .9 which is the end through the rpm range ur gonna use ur nitrous. Unusually change all rpm ranges for customer. Better safe than sorry. And as far as IPC.
IPC is a software than the new fed PCM has in the main processor. What it does is monitors driver desire torque and compares it to an actual calculated torque and takes appropriate attraction. And because the main processor along with the IPC are subject to the same failure mode they added an E qizzer. The E quizzed job is to act as a "watch dog" and checking the IPC is doing it's job. And if the E quizzed feels that the IPC is impaired it will go to a FMEM. " wrench light".
Having that said. I do alot of supercharging and turbo tunes. And if this scalar is moved up. Then a wrench lamp will turn on and go into FMEM. So it's a MUST. I use the number 500,000 works great. I'm sure other software may do it a different way but this is how I do it. Again I'm not here to talk smack. Just here to help.
