US-1
Banned
I use Shell 93 every time. No problems.
The lock ring wasn't fully seated. I fixed it, which is a bitch to do with only two hands....
If you're asking what I meant by not seated, take a look at the picture I attached on page 1. The tab at the top of the pic is not under the black guide, like the others are in the picture. That was apparently letting some fumes out.I don't understand what you mean.. could you explain a little more??
If you meant why was it a bitch, because you have to push the fuel pump basket into the hole a little to compress the o-ring and make the lock ring tabs clear their guides. So it's kinda hard to push down on the top of the basket while turning the lock ring. I can see where the ($93!!!!) wrench from Ford would come in handy, but I just used a flat-head screwdriver and a rubber mallot.
What shop was it?
Interesting. PSI did mine too... the pumps, -8 lines, and Aeromotive fuel rails. The rails started leaking in my driveway the next day, like a waterfall of fuel, and they basically gave me a screw you attitude. And they're insisting the lock ring was installed properly; it obviously wasn't. I wonder why they'd kiss your butt with a tow truck and not mine... I've spent thousands of dollars there.psi motorsports, They have always done nice work for me, except for this incedent. I called and told them what was happening, and they sent and paid for a tow truck to come get my car so they could fix it.
I fought this same battle last winter. The problem i had was that the fuel cross over from the pass. side was not pumping/sucking the fuel to the drivers side where the pumps are. When you know your getting low on gas pop open the pass access hole and see if the pass side is still full. you have to be very carefull lowering the pumps into the tank because the cross over line will pop off easily. I ended up using zip ties to hold the line inplace so it would not pop off during re-install. Maybe your really getting around 24mpg (whitch sounds about right) and its only using half the tanks compasity???
http://www.modularfords.com/forums/showthread.php?t=107000&page=1
Thanks again for the info.I'm pretty sure that on the GT500 pumps even though it's a 6 pin connector the pin numbers remain the same.
I've done 2 of them so far and I never needed to drop the tank.Thanks again for the info.
I waited until the fuel level dropped to zero and tried measuring the resistance on my GT500 connector. I got all zeros no matter which pins I used, so I guess this confirms that the sender is shot.
I'm gonna drop the tank and put in a new sending unit tomorrow. It sucks that they only give you a half-assed access hole to do it from the back seat.
Ive pulled mine more than I want to admit. LOL!I've done 2 of them so far and I never needed to drop the tank.
As a matter of fact it's never taken me more than 15 minutes to get a pump out and another one in.
