wheel hop
cobra mike
rice killer
amelia va
does any of your cars wheel hop, mine does it bad when you try to launch, and it just spins a little, havent tred to just do a burnout yet.. and when i hit 2nd, and 3rd it hops, but not as bad. i just want to know if its normal, if not ill take it back, and have it fixed, if its normal, ill get some contol arms and relocation brakets.
RedFire07GT
11sec N/A 3V
Ocean County, NJ
Running some CHE lcas on my 07, they work great! With some relocation brackets too. Still using the OEM UCA.
Sent from my Droid using Tapatalk
BAKnBLK2010
Harley Davidson FLHTCI
Sandy Hook Kentucky
My 2010 hopped bad. I got the UMI lowers with relocation brackets and they work great. They are 100% American made and are quite a bit less expensive than some of the others out there.
Riptide
Will work for Mustang.
Montucky
The UMI are a bit harder to install than say the BMR for instance but they might be a little bit more stout especially if you aren't going to weld right away.
UMI Sales
Philipsburg, Pa
Hello
Thanks guys for suggesting UMI Performance. When it comes to eliminating wheel hop. Our traction package is the #1 option due to either stock or lowered ride height. They will allow you to adjust the control arm changing your instant center and increases your traction performance as well as eliminating wheel hop. Below is a link to show you what we have to offer.
http://www.umiperformance.com/catal...ducts_id=320&zenid=0sb9bn7v4tatff19rm3nfkd7g4
If you have any other questions feel free to ask! And when you purchase from UMI Performance you are not only getting a great quality product that performs. You are also getting great customer support and tech advice during and after the install.
Thanks Again
Brad :D
SirKnightTG
Deep in the <3 of Texas!
I have that ^^^
Works well and looks good too! Also costs the least. But, I get A LOT of squeaking from it. I don't know if that's just the way it is, or I have the bolts on too tight or what. I added enough grease. Which I probably need to see if they want any more. It's been about a half a year or so since install.
Riptide
Montucky
Poly bushings seem kinda high maintenance IME. The ones I had, after 10k miles, were badly grease starved. I wouldn't let them go more than 6K or 1 year before checking and re-greasing them. They didn't look damaged to me but there was very little grease left. If you have zerk points you should make sure to give it 1-2 pumps at least once a year and also make sure you grease the outside of the bushings manually. The zerks won't grease that area.
If you get the UMI brackets I have a couple suggestions. For one, follow the instructions and do the passenger side first. It mentions lining up the hole for the dampener bolt and running that one first. Lining up the brackets, which are tight, is a pain in the ass. It's worse if you don't start with the dampener bolt first. And also, their instructions are wrong on the torque settings for the Ford bolts. They are supposed to be 129ft. lbs. not 100.
cobra mike
rice killer
amelia va
thanks for the input, i guess ill be getting some, im afraid its going to break somthing..199 not a bad price
foolio2k4
Buena Park, CA
Normal.
Lca will diminish it. I dont have uppers though. I have a set of springs/shocks and took away all wheel hop
luillo
Fort Walton Beach, Florida
well, just to make sure i will ask. Is the upper Control Arm on the 2011 GT the same as the 2005-2009 and only the bracket is the one that change???
I ask to verify if i could use my old Adjustable CHE Upper Control Arm on my 2011 and then wait for CHE to develope the bracket.
