Which Knock Sensor DMR for logging knock?
StockishS197
Houston
When logging with LiveLink, which PID/DMR should I use to datalog knock sensors adding or pulling timing? When I look at available DMRs, I see Knock Sensor Add KS followed by a number 0-10. PCM Stratrgy is FPAFO3 if it matters
Thanks.
StockishS197
Houston
Last time I looked at the K sensors I think I was looking at the PID for 1 and 2. You can also log 2 or 3 timing PIDs and see how it is affected.
Yeah for mine, I found that the knock KS add PIDs 1-5 show the knock sensors adjusting timing all about the same, so seems like I can just pull one of those.
