Whippled,caged, 2007 GT/CS F/S
gtcs07
Im just kinda here
New Jersey
Alright guys im putting this up to see if i can bring myself to get rid of it.
28k o.b.o. and its yours including almost every spare and stock part for the car.
2007 Redfire metallic GT california special
38k on the body
7k on the built rear
20k on the motor
10-15k on all parts if not less
-Cervinis type IV hood with ram air
-Shelby GT500 Hood pins
-Billet antenna delete
-Agent 47 lower brake cooling scoops
-Roush 9 bar billet grille
-Shelby billet lower grille
-Street scenes headlight splitters
-Black Corner markers
-Hids in headlights
-cdc windshield washer squirter relocation kit
-cdc quarter window scoops
-2010+ Side mirrors
-window vent shades
-GTO solar wing
-Steeda Race wing
-CDC rear tail panel
-SHR Billet gas door
-Tinted tail lights
-sequential taillights
-led third brake light
-30% tint all around
-Roush RTC suede seat covers
-GT/CS dead pedal
-GT500 KR Dash
-Saleen 200 mph gauge cluster
-Steeda hollow point lock pins
-Steeda center console/radio trim
-MGW billet ebrake handle
-MGW Cup holder trim
-Steeda HVAC knobs
-GT500 Steering Wheel
-GT500 shift boot
-Mustang embroidered console lid wrap
-Aluminum quarter window deletes
-MGW chrome shifter with Rally shift knob
-Scott Drake brushed pedal covers
-Steeda power seat button
-3D Carbon Chrome door sills
-3d Carbon Speaker covers
-Autometer 3 gauge dash pod
-SOS 3 pillar pod
-Autometer Cobalt series, digital tachometer, Oil temp, boost ,oil pressure, fuel pressure and AEM wideband gauges
-FRPP push button start kit
-Mustang embroidered Trunk carpeting
-Ford Racing High Output Whipple Supercharger
-Reichard Racing 3.4 Pulley
-34 lb injectors
-UPR billet belt tensioner
-GT500 Dual Fuel Pumps
-trick flow 2v chain tensioners
-MSD Coil packs
-BBK 62mm Throttle body
-JLT oil seperator
-BBR adjustable motor mounts
-Custom powdercoated valve covers
- MMR 7 qy oil pan
-Moroso Fuse box-master cylinder cover
-Billet engine caps
-Hooker long tube headers
-JBA catted H-pipe
-Magnaflow Magnapack Catback
-Diablo sport Trinity tuner
-SPEC billet steel flywheel
-SPEC stage3 clutch
-RAM heavy duty adjustable slave cylinder
-MGW Short throw shifter
-Spydershaft aluminum driveshaft
-Welded axle tubes
-Eaton Detroit TruTrack
-FRPP 4.10 gears
-Moser 31 spline axles
-FRPP Rear end girdle
-Radiator extension covers
-Steeda sport springs
-FRPP shocks and struts
-GT500 strut caps
-Ford Racing Strut tower bar
-Steeda lightweight radiator support
-Ford racing Sway bars
-Bmr driveshaft loop
-CHE Gtrac brace with torque limiters
-Granatelli rear shock tower bar
-Steeda upper and mid trunk braces
-Maximum Motorsports 6 point roll cage
-Bmr non adjustable tubular a arms
-Granatelli full length sub frame connectors
-Steeda billet lower control arms
-Edelbrock adjustable upper control arm
-BMR upper control arm bracket
-Competition engineering adjustable panhard bar
-BMR upper panhard brace
-BMR panhard bar relocation bracket
-Che rear end brace
-Steeda Ultralite wheels
-Baer Deceala Rotors
-14" Brembos up front
-Hawk HPS pads
-GMS Tyre Fryer line lock
-All braided brake lines
IM NOT PARTING IT OUT AT THIS TIME SO PLEASE DONT ASK
Car no longer has projectors and will have black steeda ultralights instead of gt4s unless buyer has preference
Car has only seen the dragstrip maybe 6 times in its life never a road course but is ready to do both
NjsGT
Back in the game....
NJ
Ok guys, Ive seen this car in person and its absolutely immaculate.... Alot of hard work went into this car... The OP is also a stand up guy..... Great deal here if you ask me.... BUMP for you Dan
Windveil Blue
Absolutely a beautiful car and it will impress you. I witnessed its transformation from a stock GT/CS to what it is now and the car is all done right. Dan knows his stuff and no corners were cut. This car is built for speed and handles. You need to go for a ride in it and see for yourself. You will not believe how well it takes corners and accelerates. This is a very streetable car too... Sad to see it up here for sale but on the flipside I wish I had the cash to buy it.
gtcs07
Im just kinda here
New Jersey
Thank you chris
Just to let everyone know the car just recently passed inspection and will come with an offroad x pipe as well as the catted h pipe
NjsGT
NJ
Hey Dan, which frpp STB is that? Wonder if that would fit over my frpp manifold....
gtcs07
Im just kinda here
New Jersey
Its off the svtpp gt500s. It wont clear the frpp though you need a bullit stb
NjsGT
NJ
back to the bullit stb... damn it lol thanx man. Hope this sale goes quick to I can test drive your next project :naughty1: Then Ill be selling my car on here next lol
Greg Hazlett
Stepping on the Pink Bus
Chesapeake, VA
Not true; the 2010 GT STB fits on the 05-09's with the FRPP intake! Jeremy (Lightblade) has it on his 07.
skwerl
tree hugger
central Florida
I have both a Bullitt and a GT500 shock tower brace and neither one of them fit over top of my m90. If I space them up then they hit the hood. The only way I'm getting a STB on this car again is if I replace the K members and use the lowering motor mounts.
Back on topic, the car looks amazing. You've put a lot of work and money into it. :thumb:
Greg Hazlett
Chesapeake, VA
Gotcha....but it is a relatively inexpensive alterntative and my STB on my 2010 fit over the FRPP manifold as well...was suggesting it to the guy who asked of the Bullit was the only option.
