I don’t want to get into a flame war over this but I figured I would contribute something. Ford’s pannard bar location is a compromise - Why – Ground clearance for the street.
A proper panhard bar is heim or solid jointed, as long as possible and located as low as possible / parallel to the axle / ground (Which defines the roll center). This setup is light, strong and very efficient. With proper spring rates, suspension deflection is minimal on the track. Running a comparison between a proper watts link and the stock mounted pannard par is ludicrous - of course the watts will be better. I am a weight fanatic when it comes to racing – myself excluded. I would rather not add 20 to 30 lbs to the back of the car unless I had a class specific weight requirement to meet and if I did I would prefer to add it where I wanted it and not to an overly heavy axle and far back from the rotational center or the car.
There is nothing wrong with a straight axle on a smooth surface. Both wheels are parallel to the ground and stay that way. The axle can be modified to induce permanently fixed negative camber and or toe - in some circumstances more than 1+ degrees though I don’t recommend that much – bearing life is severely compromised. The problems arise when there are surface irregularities. With an independent rear suspension each wheel moves separately. With a straight axle, when one tire hits a bump, it affects the other. Irregular surfaces are a straight axles nightmare – overly raised apexes for example.
This is why I think for the weight class the BMW is far superior to the mustang just low on torque, which is usually what gets you to the next corner first.
