I have a Auto Meter Nexus wide band on my car and Lito has been finishing my remote tune but to finish it he needs the wide band data to make sure it's good to , any way the problem is the wide band cycles on and works perfectly one minute but then when I crank the car up say an hr or so later the gauge will cycle on but then goes straight to - - - - on the gauge display. Thinking maybe I had a bad wide band sensor I changed it out with a Auto Meter replacement one, but the wide band is doing the same as before, anyone know what might be going on with it? I'm stomp at this point... The other gauges are working fine so not sure if my nexus controller is messing up or what.. any info would be appreciated...
