To be clear-I have no clue what Im doing but Im trying to learn so looking for some help here. Have searched, but not finding specific answers to my questions.
So- I am in the process of wiring a 9 pin din cable to the Autometer/Cobalt Wideband in order to get it to talk to my SCT II tuner for Datalogging
Wideband has the following wires:
a) Power/red- That one I get. Got the add a fuse for plugging it in.
b) Wot Switch/Brown wire- I dont have a Wot switch- So my understanding is that its best to ground this to the engine. Yes or no? If no What do I do with it?
c) Data Logger Ground/ Blue Black - Not sure if this goes to Analog 1 or Analog 2 or the Ground on the SCT.
d) Positive datalogger output/blue-Not sure if this goes to Analog 1 or Analog 2
e) Ground/black. Not sure if this simply gets grounded or uses the SCT Ground pin via the DIN cable
SCT/Din Cable has:
f) Ground/Brown (Does the Autometer wire Datalogger Ground or the Ground wire attach to this?)
g) Analog 1/ Green- Not sure what to do with it- Is it for the Positive or Negative Date logger wire?
h) Analog 2/Gray Not sure what to do with it- Is it for the Positive or Negative Date logger wire?
So if anyone could chime in even if its to tell me to back the f away from wiring because I dont know what Im doing. Please. All input welcome. And Yes VMP does have premade wires for attaching widebands to tuners, but not for the SCT II, I checked otherwise I would have gone that route.
SCT/Din Cable has:
