Winter Storage Tire Care: What do you guys do?
Jeepngli
Anti-LS1
NJ
So I am about to store the car for the winter. Last winter I garaged it all winter but had a longer garage. I would start it up once a week, let it get all the way up to temp and run it a little longer. I would then roll the car back and forth so it didn't stay in the same spot for long.
I now have a smaller garage. I think I can still do the same thing, but I'm wondering about using Flat Stoppers by Race Ramps.
Waste of money?
tjm73
of Omicron Persei 8
Rush, NY
i just park and dont touch it until spring
^^^^ this. Been doing exactly this for over 15 years with a half tank of fuel and disconnecting the battery. Be sure you disconnect the battery and open the drivers door when you do it. The glass drops about 1/4" and when the battery is disconnected it will stay down slightly and not drag on the trim when you open the door with the battery unhooked.
SteveP
Modular Specialist
Boynton Beach, FL
moth balls (engine bay and around tires) and a moisture absorber (inside), and battery switch off. All I ever did. No issues.
Jeepngli
Anti-LS1
NJ
I can't jack it up because if the complex I'm in catches me they will take away the garage and don't wanna chance it.
So no one has tire issues? I guess I'll just leave it and roll it once and awhile and then take out the battery.
Good call on the windows down thing
tjm73
of Omicron Persei 8
Rush, NY
Radial tires (properly inflated) don't normally get flat spots and if they do, they are gone as soon as the tires warm up a little bit.
If jack stands are an issue get some 12"x12"x1/2" hard wood squares and place them under the jack stands. That would distribute and cushion the load and would not damage any floor surfaces.
Shotokan1509
CT
I add a few extra psi over normal pressure, zero issues from Thanksgiving-Easter
Vapour Trails
The Renaissance Man
Winnipeg, MB, Canada
Don't worry about flat spots, it's much ado about nothing.
Don't start the engine periodically, just leave it until you are going to take it out of storage. Put in a fuel stabilizer product then top the gas up to the brim (add the stabilizer at the gas station). Drive/run the car for 10 minutes to get the stabilizer well into the fuel system.
tjm73
of Omicron Persei 8
Rush, NY
I have never used fuel stabilizer and have yet to suffer any ill effects in over 15 years of winter storage of vehicles. I think fuel stabilizers are modern day snake oils. Utterly unnecessary. The automotive equivalent of the traveling "health tonic" salesmen so oft parodied in TV and movies.
Nothing more than slick marketing for a problem that does not exist.
50tbrd88
Bloomfield, IN
Me too...I did buy a "battery maintainer" and put on it too. I top it off with fuel and add Stabil and she sits there quietly in the corner until spring.
As far as fuel stabilizers go, the reason I run them is from what I have seen where I work (John Deere dealer). We have seen a lot of problems the last few years with bad gas in lawnmowers and stuff in the spring. People bring them in running like crap or not running like all. Our tech just drains the gas, changes the filter and boom, runs like a top.
Shotokan1509
CT
I disagree, every year we used to have issues with our snowblower, tear it all down clean lines, etc. Then it would be cranky all season. Once we started using Stabil we've had zero issues, starts first pull after being in storage all summer.
50tbrd88
Bloomfield, IN
I have a '72 Chevelle that literally sat in the exact same spot for 14 or 15 years until I got it going again. It has some BFG radial t/a's from the 70's on it and all I did was air them up and go, lol!
frank s
at Play
Paradise
There is a tire problem with racing compounds. My serious-but-seldom racer friends roll the tires up in cling-wrap so the tread doesn't harden from storage and disuse. Other than that, not much need to do other than ensure there is enough air in your street tires to keep them pretty round until they are to be used again.
tjm73
of Omicron Persei 8
Rush, NY
Lawnmower and snowblower fuel systems are no where near as sealed as automotive fuel systems. If exposed to air the fuel evaporates and can cause problems. That is very true. I can see problems arising if we are talking about those small engines.
But when we talk about modern cars and the fuel systems they have with the emissions controls and such, the problem is not there.
Shotokan1509
CT
Ya, ok maybe that is a valid argument.. but I'll play it safe and spent a few dollars every year rather than having a small possibility of a bigger problem come spring.
tjm73
of Omicron Persei 8
Rush, NY
Probably won't have any negative effect.
But keeping a rock in my pocket is just as effective at keeping lions from attacking me as fuel stabilizer is at protecting automotive fuel systems. And the rock doesn't have any negative effects either.
S197gt07
Newburyport, MA
Brian,
I've stored my car for 4 winters at this point. All I do is the following
1) Inflate tires to 45psi
2) Put dryer sheets in cabin to keep it smelling "nice"
3) Battery Tender
Thats it. Every spring, it fires up no problem. Don't over think it
Also, I never start it over the time its stored (usually 4-5 months). I don't think its necessary to start the car once per week, and let it idle for 15min to warm up, just to shut it off again.
